Topic: [Solved] Digiface USB sync clock won't stay synced
Hi there,
Running a DigiFace USB (serial #24062457) with a Prism Orpheus in Direct ADAT Mode. The clock won't stay synced on any of ADATs 1-4 for longer than 10-15 seconds at a time. The Input Status switches between "lock" and "sync" continually. This happens at 44.1khz and 48khz.
I recently switched to the Digiface from a Fireface UC. The Fireface was syncing with no issues with the Orpheus. All the settings and cables are the same on the Orpheus. I have also tried 3 different toslink cables to check it's not an error there.
- OSX Catalina
- Firmware 18
- Totalmix 1.22
- Clock set as internal
Any help would be greatly appreciated!
