Topic: Compression visualizer doesn't work on outputs 191/192 of MADI FX
Running into a weird issue where the compression visualizer doesn't work on the 191/192 output channels of my MADI FX card when viewed in TotalMix.
Sorry, this may be the wrong section to be posting in, wasn't sure if this should go in the HDSPe section or the TotalMix section. Nevertheless, here's a gif displaying the issue:
As can be seen, the ball doesn't slide up and down the track on output channels 191/192, in my case this channel is named "Mic Submix", the channel named "Test" are channels 189/190 and as you can see are working fine. As far as I can tell, this issue is limited specifically to the output channels 191/192. The visualization even works fine on the input channels for 191/192.
Was going to apply some compression to the channel. I still can, and the compression appears to apply, but it's hard to dial in without the visualizer. Thinking this is maybe a bug? Any ideas?
