1 (edited by Alexdisplaynameforrme 2022-05-17 09:52:09)
Topic: UCX II screw-on feet
Hi, I'd like to replace glue-on stock rubber feet with a set of screw-on feet.
  • Which screws can be safely replaced at the bottom of the interface?
  • Which screws do i need to use? The stock ones are very short and i need longer screws.
Edit: I've solved it by using 3M double sided adhesive tape to attach new rubber feet, it works fine.
