Topic: Some questions on the ADI-2 Pro
Dear Forum Members,
I have a number of questions on the ADI-2 Pro (specifically the ADI-2 Pro FS R Black Edition)
and I would very much appreciate if someone could help me out.
I should also add that I am a relative 'newbie' to the realm of digital audio so I'll apologize
in advance if my questions seem silly - it's just that I don't know any better (at this stage!).
I have a large FLAC collection (13000+ files) stored on a Synology DS213+ NAS.
Typically I play music via my PC (I work from home) using the HQPlayer software.
Yes -I like very much to upsample - I have a very powerful Windows 10 based PC so I can use the
more powerful upsampling filters that HQPlayer provides (it's very good by the way).
I am a headphone listener.
Currently I am playing my music through a PC audio card - a Rog Card :
https://www.asus.com/microsite/mb/ROG-s … #supremefx
At it's maximum it can accept 24 bit / 192 kHz upsampled music.
but I want to upgrade to a top notch DAC that can accept upsampled content via HQPlayer
at the highest level possible.
I have been reading about many DACs - but the ADI-2 Pro FS R Black Edition with its
twin DACs and incredible implementation has really caught my eye.
I especially like the excellent protection facilities built into the ADI-2 which protect headphones from
being damaged / destroyed by power spikes (I have read about other very expensive units where
both the OpAmps and headphones have been cooked on power up. That same unit also warns about taking out
headphones during playback - something which bothers me).
So given all this, my questions are :
1) Can the ADI-2 Pro FS R Black Edition play back in a balanced mode to a set
of good headphones? I know that the ADI-2 can be run in balanced mode (from the settings) but
do I need to do anything special top with headphones? For example, if I were to use a pair of
Audeze LCD-2's, would a connector with a double connection for the ADI-2 side front headphone jacks to
a single connector to the headphones work? Can this balanced setting be used with any headphones as long as I have the connector?
2) As stated earlier, I run a Windows 10 PC.
I read somewhere (and I'm likely confused) that if I connected the PC to the ADI-2 via USB
that because of the Windows drivers and limitations around those, I would be limited to :
- PCM @ 24 bit / 384 kHz
- DSD @ 256
Is this true?
I hope not since I would love to push the ADI-2 to it's limits with HQPlayer @ 24 bit / 768 kHz.
Any guidance on this would be great.
3) Can the binaural crossfeeds be used in the Balanced mode?
I'm very keen to try these out since I have read that a strong implementation of this
technology (as in the ADI-2 Pro FS R Black Edition) sounds very good.
4) Which DAC chips does the ADI-2 Pro FS R Black Edition use now?
Still the ESS chips or back to the AKA's (since I read somewhere the factory has been repaired).
I understand that it won't make a big difference since there is a heap of high tech RME components
in the ADI-2 Pro FS R Black Edition but I'm just curious.
5) Any guidance on a great pdf book on audio engineering terms (for newbies) would be appreciated.
I'm quite keen to learn more and that's another plus for the ADI-2 Pro FS R Black Edition.
That's about it for now.
Any help / guidance would be much appreciated and I'd like to thank everyone in advance
for reading through my post.
Finally, many thanks to RME for conceptualizing and building such an incredible piece of kit.
I came across it almost by chance - it wasn't being sold in the 'audiophile' stores where
I live (Melbourne, Australia) but rather by sound engineering / Pro DJ stores.
Quite surprising to me given it's power (ie. running a FPGA like some of the most
expensive DACs available - if I remember correctly).
Cheers,
Adrian.
