Topic: ADI-2 DAC Pre-set Volume at Startup
Hi, from a user friendliness perspective is there a chance to have in one of the forthcoming firmware releases the feature of a pre-set volume setting at startup imlemented. With this setting on/off one should have the chance to use a individually fixed volume at startup, otherwise off would react as just it is. This feature would be great to avoid the level setting every time the DAC is started up in case needed.
