Topic: Correction in MIDI command for Trim Gains on UCX II
I believe there is an error in the User Guide for the UCX II, v1.2b, with PDF date-stamped 24Oct2021.
Page 87 give the MIDI for Trim Gain Off as:
Trim Gains Off: BC 66 xx or select a submix
... I believe the CC# is incorrect and should read (based on my experimentation):
Trim Gains Off: BC 67 xx or select a submix
Also, I'm not clear on what "select a submix" means ...
WindSynth:Sylphyo Cantabile Ableton Push3S
