Topic: Help on volume display on ADI-2 PRO
On my ADI-2 PRO the display shows only the left channel when I listen from USB.
Is very strange because the output signal are correct and if I listen from optical input, then I see also the right channel.
I already made a factory reset and the firmware update.
I also see a bit of signal on analog inputs, but I don't use this inputs!
You can see the display here: https://ibb.co/tLXfZ8J
I hope someone can help me!
