1 (edited by Oetzi1977 2022-06-08 16:45:38)
Topic: Babyface Pro FS with Linux MX - input level in CC Mode [SOLVED]
Hi, I'm using Babyface Pro FS with MX-Linux and work pretty well, but I can't find an info in my manual:
How can I adjust input gain when in class compliant mode?
Re: Babyface Pro FS with Linux MX - input level in CC Mode [SOLVED]
On the device itself...
What does it mean exactly?
I asked because I don't know how... On the device itself... Nice answer but selecting what? Pressing which buttons? A more detailed answer will be appreciated, thanks
More details about operation are in the manual - did you have a look there?
5 (edited by Oetzi1977 2022-06-08 16:19:06)
Is it in the Class Compliant section? I didn't find it.
It's forbidden to ask anything that is reported in the manual? It's a milestone rule of this forum?
Ok, it's not in the class compliant section of the manual, it's page 9, pressing IN to select input then push SELECT to switch between l/r/stereo and then the wheel to select level.
I've used always in PC mode doing it in TotalMix FX, but probably the tech support consider everyone who got the same question an idiot... not bad for a soundcard buyed for more than six hundred bucks with a "great" support. Not bad, really.
It's not in the CC section of the manual because it's not a CC specific functionality. It's basic operation at/of the unit.
We provide these manuals to enable you to familiarize yourself with the device....
