The Excel only contains USB/FW/TB interfaces, no PCI/PCIe cards.
FYI:
- DURec only with UFX+, UFX II, UCX II ...
As an alternative: DIGIcheck Globalrecord (Windows only).
- If you want FX ...
HDSPe MADI FX is the only PCI card with FX chip on board
Full implementation of FX chip on: 802, UCX II, UFX II, UFX+, MADIface XT
If you need Instr ports, look at the details, e.g. MADIface XT has 2 Mic/line inputs, but can't be set to be Hi-Z/Instr ports.
So in a few cases look at the details.
Regarding 12 analog ports on the UFX+. Well yes you can use 4 Mic and 2 phones in/outputs as analog ports, but if you want to use it to connect external gear, then you have no mic ports anymore and you have no phones outputs for monitoring through headphones.
I regard it better to distinguish analog ports into these groups as they have usually different use cases:
- unbalanced analog inputs for mic/inst/line (not all combo ports suppot inst/Hi-Z -> e.g. MADIface XT)
- unbalanced analog outputs for headphones
- analog line inputs, servosymmetric (supports balanced / unbalanced)
- analog line output, servosymmetric (supports balanced / unbalanced)
