1 (edited by soundflix 2022-08-16 14:25:02)
Topic: Bug: Using Speaker B on ARC can change volume setting!
Hi all,
I think I found a bug in TM FX 1.75. (Driver package 3.39 on macOS Catalina).
Using SpeakerB button on ARC can change SpeakerB volume setting inadvertedly if you have a volume offset between Main and SpeakerB.
In the worst case, both volumes raise until they are at + 6dB!
Here's a Screencast.
https://i.ibb.co/mqkYFdg/Total-Mix3-39-Bug-linked-Speaker-B-with-volume-offset.gif
First half I'm clicking with mouse, then I use ARC SpeakerB button. This is Case 3.
Offset values with .3, .4, .5, .6 ,.7 decimals are buggy.
.0, .1 , .2, .8, .9 are not buggy.
Here's how to reproduce the issue(s):
Case 1:
Put volume of Control Rool MAIN to 0.0 dB, SpeakerB to 0.6. Don't LINK.
a. Now push SpeakerB in TM: volume values stay same, as expected.
b. Now push SpeakerB on ARC: volume SpeakerB jumps to 1.0 dB! Bad. Well, at least value is rounded up or down once.
Case 2:
Put volume of Control Rool MAIN to 0.0 dB, SpeakerB to 0.6. LINK them.
b.Now push SpeakerB on ARC: volume SpeakerB jumps to 1.0, Main to 0.4. BAD! Disengaging SpeakerB on ARC the values go back to 0.6/0.0. But: Disengaging SpeakerB in TM the values stay at 1.0/0.4! WORSE!
Case 3:
Put volume of Control Room MAIN to 0.0 dB, SpeakerB to 0.5. LINK them. (you may have to click on dB value to enter with keyboard)
b. Now push SpeakerB on ARC: volume SpeakerB jumps to 1.0, Main to 0.5. BAD! Disengaging SpeakerB on ARC the values go to 1.5/1.0. WORSE! AND: Each push of SpeakerB on ARC continues to raise both volumes! Aaargh!
I think the issue stems from a rounding issue between clean dB display values and the actual 'dirty' decimal values that are underlying. I noticed already while working with OSC that there is something going with the scaler function inside TM.
I haven't checked how it is with macOS 11/12.
For now, I'm just NOT using a .5 increment offset between the two, to work around the issue. But it really drove me nuts until I knew what's going on.
I hope this can be fixed in the future.
Re: Bug: Using Speaker B on ARC can change volume setting!
Same behavior on macOS 12.4, TM FX 1.75 (driver 3.41)
I am not seeing this behaviour (OS 12.4 & OS 12.5)
Matt McKenzie-Smith (UFXII, UFX, Babyface) MacStudioUltra OS13.2.1
By the way, it is not possible to watch the video without having an account on Vimeo.
I hopefully fixed it with an embedded video.
6 (edited by soundflix 2022-08-02 11:06:30)
I tested this on iMac 2020 10.15 and 12.4 with FF400.
And on MacPro 2019 10.15 with Babyface Pro (1st gen).
Everywhere the same.
For me, values with .3, .4, .5, .6 ,.7 are buggy.
Thank to the teachings of Manuel from another thread I managed to put up the screencast as gif, so everyone can see this.
Small update, I still can replicate this.
If one or both of the channels are mute, values don't climb.
