Topic: ARC USB - Volume wheel resolution / speed setting
Hi fellow RME users!
I have a quick question.
Since today the volume wheel on my ARC remote looks to be set to macro mode or something, when I change my volume I need to turn the wheel multiple times to change the volume of my speakers for about 1 or 2 db. This always took only half of spin on the wheel, I don't remember changing anything. I have looked in the Arc & Key Command Settings in Totalmix but I don't see anything about wheel resolution or speed.
Is there a way to change the wheel resolution?
Thank you!
Cheers,
Morris
Logic Pro X | RME Fireface UFX | ARC USB
Re: ARC USB - Volume wheel resolution / speed setting
In TotalMix FX, see Options -> ARC & Key Commands... -> ARC USB Settings
Is "Default Encoder Function" set on "Volume Main (0.1 dB)" ?
If so, try to set it back to "Volume Main (Default)".
Cheers,
Laurent
Intel i7, Windows 10, RME UFX+, ADI-2 Pro FS R BE, ADI-2 FS, Ferrofish Pulsar16 MX
Thanks for this! I wonder what caused sudden resolution change for me too!
