wommas wrote:Hi everyone,
I just bought a Fireface UCXII because I needed more inputs for recording my synths and also because I was looking for a better DAC and headphone amplifier. Coming from an Audient iD14 mkII the difference in performance and stability is insane and I much prefer the fuller sound of the RME.
The only thing I'm not really satisfied with is the headphone output; it drives my Austrian Audio Hi-X65 just fine but I found it to lack details and punch. I tried both the high and low settings on Totalmix and it doesn't make much difference. I connected my Monolith THX 887 and noticed a big improvement in details and punch but I never liked the sound of that thing, it widens the stereo field too much to the point of sounding artificial and it is too weak on low bass.
Recently I've been producing and mixing more on headphones and I'm using my monitors as reference. I'm using SoundSource on a Mac with Canopener for crossfeed and Morphit for eq.
So in the last few days I've been thinking about two solutions:
1 - Getting an ADI-2 DAC FS (the Pro is too expensive for me at the moment) and connect a preamp or audio interface via ADAT to record external instruments (or using a USB audio interface for the inputs).
2 - Sticking with the Fireface UCXII and buy a better external headphone amp.
The fact that the ADI-2 DAC FS has the built-in eq and crossfeed makes it very tempting but I don't know if it would be a noticeable improvement over the UCXII in sound quality, concerning DAC and headphone amp specifically.
Sorry for the long post but I can't stop thinking about this and I didn't know where else to ask.
Buying a better external headphone amp is a must. Don't listen to people who say the difference is negligible, they probably have never mixed on headphones extensively and don't know what they're talking about.
I'm mixing 95% of the time on headphones since I have annoying neighbours and no treated room anyway (only checking translation from time to time on my speakers) and it only really became possible as I bought a dedicated quality headphone amp. I make electronic & dancefloor oriented music and without this combination you won't be able to push at satisfactory high levels (from time to time, of course) to check that your music at 0db sounds great and loud like your reference tracks. Also I've noticed while mixing that amps allow for much more clarity and details in lows/mids/highs, it opens up and make the most of your headphones.
Where I started out I tried the usual budget devices like Scarlett 2nd/3rd gen, Motu (M4, which I still own, best portable USB-driven interface in this category, but limited in power precisely due to USB), Audiotent ID14 MK1, which all around have headphone output around 113/118dbish. Not good enough. I found out later that only the Audiotent MK2 had loud-ish headphone amp (125.5db) in this price range but even so I'd recommend always getting an external amp.
https://d9w4fhj63j193.cloudfront.net/20 … l%20V1.pdf [ID14 MK2]
The reason for that obviously is the fact that, at this price point, you can't expect a good built headphone amp to be included in the sound interface. Also, having a dedicated external amp will you not only the power you need to drive hungry (or even normal) headphones, but also more dynamics in combination with the soundcard's external output.
I'm not surprised the UCX II is disappointing when it comes to the headphone amp (113-115db only??), because again, I've never come across a good built-in amp unless you pay more than 2/3k for a sound interface.
The only brand that comes to mind with very good built in amp is the UAD series, for example the Apollo Twin X is known for being powerful with output dynamic range of 127DB and headphone output of 124DB (and better converters than the entry-level competitors obviously)
https://media.uaudio.com/support/manual … Manual.pdf [Apollo Twin X]
That said, I hate UAD locked system and love everything about RME, including TotalMix and the way it integrates seamlessly with my setup and workflow, so I'm still gonna go for the UCX II because for me it's the best sound interface still as of 2022 at this price point and for my needs. I don't need anything more expensive with more inputs as I do most of my stuff in the box with plugins anyway, a couple hardware synths maybe max. (I'll probably upgrade with the UCX III in the future, hoping they improve the low dynamic range and headphone amp situation to match UAD's. Or the UFX III if they come up with it before (likely), if I need the extra inputs it provides.
And also, because, and this is key, I'm using an external amp. I have noticed RME products are more quiet vs. the competition in terms of dynamic range (115db only for the UCX II!!), so you absolutely need to be aware of this and pair it with an external amp or the ADI.
https://gearspace.com/board/featured-ar … rface.html
"It’s 115dB dyn range in comparison to my Apogee Sym Desktop’s 129dB DA. The truth is if you’re gain structuring properly, it’s no biggie. I really enjoy the TotalMix software. I have had several mixes where I want to get it louder, but hey, the future looks bright for audio."
As of now I'm using the Lake People G103 S MK2 released in December (much improved and more powerful vs. the MK1), with pre-gain set on the +12db selectable, it's excellent for the price 250 EUR, cheaper than the THX/AAA series you have and best in this 200-400 eur range I believe, with very transparent sound.
https://manuals.plus/m/3c5897f78c5e3d57 … _optim.pdf [Lake People G103 S MK2]
Once I move to the UCX II though, I'll definitely replace the amp as well with the addition of a ADI-2 Pro (dynamic range of 144db) or the upcoming RME ADI-2/4 Pro SE, which I suspect will have least the same db power (if not slightly more).
The regular non-Pro ADI-2 DAC FS you're aiming for is a lot less powerful so I would advise to save up and buy one of the two aforementioned models. Really worth saving if you rely heavily on it daily.
Alternative option and cheaper amp if you want the power without RME - get the Topping A30 Pro (300-350 EUR) or even better quality the A90 Discrete (650 - 700 EUR) which is state of the art and can drive any headphone with great transparent sound. Both come with 145db dynamic range and were released this/last year. Check Audiosciencereview and other places online for full reviews.
Good luck.
