1 (edited by walth 2022-08-18 16:23:49)
Topic: Total Mix Remote + Windows 10 = No Connection
I can't get my iPad running Total Mix Remote to connect to the Total Mix server on my Windows 10 64 system. Port 7009 is unblocked for in going and out going for both TCP and UDP. There is no other filter between the iPad and the computer. Everything is enabled on the server. Any Thoughts?
On the iPad on startup, the app briefly shows "connected", but then goes "offline".
Re: Total Mix Remote + Windows 10 = No Connection
Same problem here. It once connected properly though.
iPad 3.
@Endorfinity
It's working for me, but what I found is that I needed to check "Enable User Management", then supply a user name and password for the connection. Since doing that, it has worked well.
4 (edited by Endorfinity 2023-03-26 20:36:18)
Well, in my case it turned out iPad and PC were connected to different Wi-Fi spots, all works flawlessly smile
