Topic: Fireface UC - Setting channel input missing
I am using Fireface UC and I need to use channel 1,2 with line input.
When I checking the level compared to other inputs, 3,4... it is 6dB lower.
I think there should be a setting page to change inputs but I do not find where it is.
When I checked a manual, there should be two icons shown on the right side of window panel.
However I can see only, Total mix icon. I cannot find RME with redfire(?) icon.
Does anyone know how to find one? Otherwise, I would like to know how to change my input gain settings with total mix etc.
Thank you for your help, in advance. smile
Re: Fireface UC - Setting channel input missing
Check if the icon is hidden. Else, you will find the program in windows\system32 (firefaceusb.exe), and you can copy a shortcut to the desktop from there.
