1 (edited by ploe 2022-08-20 01:23:18)
Topic: Babyface PRO and MIDI jitter - is it an issue? How about USAMO?
Hello
I want to know if it is worth to get a solution like Expert Sleepers USAMO to avoid MIDI jitter if I have a Babyface PRO.
Basically to avoid the effect of dragging and pulling of MIDI data due to jitter resulting in microtiming shifts that prevents a 100% "kraftwerk" tight rhythm.
I know other USB audio & midi interfaces suffer from jitter, but RME is known for its high quality drivers and should at least perform better.
So how much of an issue is MIDI jitter with a Babyface PRO? Have anyone measured this?
Also. I saw someone posting information that running RME Babyface Pro on an ARM based M1 Mac in Big Sur or Monterey results in less jitter than an Intel mac on previous OSX versions. Could this be true due to a hardware or software handling of the USB information being different?
