Topic: Can you save the 'exact' snapshot onto the UFX hardware...?
If I move around my UFX mk1, and would like to keep the totalmix setting the same?
Would it be possible to also save not only 'state',
but also snapshot as well onto the hardware so when I connect it to other PC,
it loads it the same?
e.g. the same main monitor naming, the same speaker b naming, hiding unneccessary channels etc?
Is it possible or I always need to load it through USB?
State has been saved to state 1 but that does not load the actual 'snapshot' status if you know what I mean...?
Cheers.
