There are three remote control options available:
1. MIDI Remote, separate application
Preamps supported: Micstasy, Octamic XTC
2. TotalMix FX, Auxdevice integration
Preamps supported: Octamic XTC
Planned: 12Mic, but delayed since a long time (COVID-19, Chip crisis, …)
See also: https://forum.rme-audio.de/viewtopic.ph … 70#p190370
Please place your “+1” there in the thread so that this gets hopefully higher Priority.
3. MIDI Remote
Preamps supported: 12Mic, AVB Tool, Octamic XTC
https://forum.rme-audio.de/viewtopic.php?id=33276
Separate application which uses MIDI over MADI.
It looks like developing a separate application was quicker doable compared to a full integration into TM FX.
I still hope that Auxdevice will be developed in the not too far future.
Note: there can be issues if you should intend to mix the different remote control solutions on one MADI bus. You get e.g., side effects (random changes on devices) when using MIDI remote (#1) and Auxdevice (#2) on devices (ADI-8 QS, Octamic XTC) which are connected to the same MADI bus. If I remember right, the Octamic XTC had issues to process/forward the two different remote control protocols at the same time.
> I currently use MADIFace Pro with MADI in from around 75-100 meters away sometime
Up to 2 km between each of the MADI devices is possible (using OM3/OM4 multimode fiber cable).
BR Ramses
