Topic: Strange stuttering issues with RME [UCX II, Babyface Pro], M1 Macbook
I have been noticing a strange issue recently which thus far only materializes on my RME interfaces. Bitwig (where I see it the most) records CPU usage spikes and the transport runs inconsistently (fast, stop, fast, stop) which I have never seen before on a DAW. I call it stuttering because of this but from an audio perspective there is no sound while this is happening.
I had thought this was a Bitwig issue but I have also seen the behavior when using the OS preview to play sound files, so possibly not. There does not seem to be a correlation with the load on the machine, since it happens frequently when not much is going on. My best theory is that somehow the audio driver is getting starved for CPU time by another application or driver, but this is a wild guess and does not explain exactly how the transport is being affected.
Here is an example video:
https://drive.google.com/file/d/1i299el … dQIrj/view
If anybody has any suggestions on how to debug this or figure out what might be causing the CPU spiking, I would appreciate it.
Thank you
__
Macbook Pro (M1 Max)
Monterey 12.4
Latest RME drivers and flash updates as of September 4 2022.
