1 (edited by skaleksi 2022-09-09 14:17:24)
Topic: Is pinging external FX via ADAT in Cubase still a no-go with RME?
at the moment I have Fireface 800 which is a great interface but the problem is that I cannot calculate the delay for external FX in Cubase when the FX are routed via ADAT (Behringer ADA8000 & ADA8200). I'm looking to buy a interface that supports this.
My question is, has this been fixed in newer models - let's say RME UFX II ?
Thanks, Aleksi
edit: To clarify, Cubase has a simple button for added external FX which calculates and adjusts the delay automatically so there would be no delay or phase issues.
2 (edited by ramses 2022-09-09 15:28:01)
Re: Is pinging external FX via ADAT in Cubase still a no-go with RME?
Aleksi, no ASIO driver in the world can predict, what device you connect through ADAT and what the converter latencies are for A/D and D/A on this unit.
The DAW can “ping” through the signal path to calculate the full latency for a signal going through the whole signal chain, like, e.g., Cubase does when adding an external FX device. Then you get full latency compensation.
3 (edited by skaleksi 2022-09-09 18:20:42)
Thanks for quick reply. Yes exactly, the latter paragraph is what I'm going after. No reason to predict the delay, that's what the delay compensation button is for. Or am I missing something?
However with Fireface 800+ADA8200 this ping comes back as zero = does not work. It does work when I use Fireface 800's own I/O's (=without ADAT).
So do you mean it is now fixed and should work with UFX II/Cubase 12/ADA8200?
I think I can get the UFX II for a test drive before buying it.
4 (edited by skaleksi 2022-09-12 14:53:21)
I figured out I can use a delay plugin like "Voxengo Sound Delay" right after the external FX to compensate the delay. In my case it sounded best when set at 48 samples.
