Topic: UFX II driver settings not supported?
Hi all,
When using the sample rate 32kHz and buffer size 2048 (set in madiface usb driver), I only get a max buffer size of 1024 samples returned by asio. When I set the buffer size to another value, the correct max buffer size is returned e.g. 512 samples in USB driver returns 512 max buffer size from asio. Is the hardware limited to only 32kHz and 1024 samples, although I can set the buffer size to 2048 in the driver?
OS: Win10
Driver Version: 0.9747
Hardware Version: 111
Thanks in advance!
Best regards,
wangyun
Re: UFX II driver settings not supported?
This is a techical limitation in the driver, sorry, and what I heard is that will not be changed.
