Topic: Using the ADI-2 as headphone amp with an external DAC
I would like to use my ADI-2 (PRO/DAC) as headphone amplifier with an external DAC connected through any of the analog inputs but so far I read in the manual the analog signal is always routed through the ADC-DSP-DAC stage before it reaches the phones outputs.
Is there a way to bypass that?
Re: Using the ADI-2 as headphone amp with an external DAC
No. But why would you want to use another DAC?
3 (edited by KaiS 2022-09-20 19:49:10)
You can use a high sample rate at ADI-2 Pro, like 192 or 384 kHz.
Then ADI-2‘s AD-DA converter’s path is so transparent that the special sound colors of your DAC come through unchanged, while benefiting from all the features ADI-2 offers.
Look at manual page 37, “Preamp Mode”, for details.
If you have an extra Optical-, Coax- or AES-digital output left from your source, connect it to ADI-2 Pro’s input, so you can switch between your DAC and the direct feed.
Make sure SRC is active for the chosen digital input, so you can stay at 192 kHz with ADI-2’s int. sample rate, which is the SRC’s upper limit.
Kai, the SRC only works up to 192 kHz, check manual ch 8.6.
Thanx, didn’t see that.
Thanks guys for the answers.
I'll give a try to the preamp mode but I am afraid this would just introduce extra unwanted processing artifacts (for minimum they can be in the ADI-2) to my already more resolver R2R DAC. But let my ears to have the final words. Still a dedicated headphone amp should be preferred.
May I ask which R2R DAC you have? Does it have better THD+N than the Adi-2 pro?
