1 (edited by ramses 2022-12-26 19:18:14)
Topic: TM FX, setup of routing for external FX (used for Amp and DAW)
In this post, I had already described my experience how positive the complete new setup or optimization of my TM FX setup went: https://forum.rme-audio.de/viewtopic.php?id=36025
Here I would like to add useful information how to best integrate external effects units so that they can be used both for the DAW as external FX or for a guitar amp.
The routings for the different use cases can be stored and recalled quickly and user-friendly in TotalMix FX Snapshots.
My main “Use Cases” for the Lexicons are as follows:
#1 – PCM81 for guitar because of modulation effects
#2 – PCM91 for mixing/mastering, but also for guitar
#3 – Both Lexicons (PCM81+91) for Cubase as external FX
For each use case, you will find a screenshot of TotalMix FX in “matrix view”. There you have the complete routing overview of all hardware outputs (aka “Submixes”) of a particular snapshot. In the screenshot, I documented the essential routing settings for the respective “Use Case”.
Here you can see now clearly, how few changes are only necessary to achieve the desired functionality.
This small documentation also answers the questions of many users, how to integrate external FX best. You just have to adjust the routing accordingly.
How to route the external FX for the DAW is shown in Use Case #3. The last screenshot shows the setup of the external FX in my DAC (Cubase 12 Pro in this case). DAWs like Cubase can then determine the latency due to the external effect, so there is then full latency compensation for the external FX so that all tracks are time-synchronized.
In conclusion, I can simply say that my cleanup efforts were fully worth it. The Matrix View now offers me a great overview because I first removed all routings and then implemented only the required routings.
Matrix View has become very helpful for debugging. You can see certain things faster than in the mixer view.
You can't say one is better than the other, both views complement each other in a nice way.
Use Case 1 – PCM81 for Amp / PCM91 for DAW
https://www.dropbox.com/s/r2lmkq18us15qxt/2022-10-03-UFX%2B-Two%20external%20FX-02%20of%2004-UseCase1-PCM81_for_Amp-PCM91_for_Cubase.jpg?dl=1
Use Case 2 – PCM91 for Amp
https://www.dropbox.com/s/4ky6ok2ou0tf2bw/2022-10-03-UFX%2B-Two%20external%20FX-03%20of%2004-UseCase2-PCM91_for_Amp.jpg?dl=1
Use Case 3 – Both PCM's as external FX for DAW
https://www.dropbox.com/s/sfqzcq27qud6mz2/2022-10-03-UFX%2B-Two%20external%20FX-04%20of%2004-UseCase3-Both_PCM_for_Cubase_as_external_FX.jpg?dl=1
Cubase 12 Pro - Audio Connections - External FX
https://www.dropbox.com/s/qiqvg22c2slng9q/2022-10-03-UFX%2B-Two%20external%20FX-01%20of%2004-Cubase12-Audioverbindungen-ExterneEffekte.jpg?dl=1
Note: the latency for external FX is quite high because I forgot to set FX to 100% dry during Cubase latency measuring. The current values are 1.5 and 2.02ms for PCM81 and PCM91.
Finally, “matrix view” & “only required routings” made it possible to check and document routings efficiently.
BR Ramses - HDSPe MADI FX, M-1620 Pro D, 12Mic, UFX III, ADI-2/4 Pro EX, Nuendo15, Win10 IoT Ent.
2 (edited by BennyBee 2024-08-06 10:25:32)
Re: TM FX, setup of routing for external FX (used for Amp and DAW)
Unfortunately I can‘t see the use cases. Are these pictures and is my browser (safari and firefox) May be to set up differently?
I am very interested how to connect my PMC91 and PCM81 with RME
3 (edited by waedi 2024-08-06 11:25:46)
You can't do anything in the browser, dropbox images don't show up in Safari in this forum. The poster may have to use an image upload service and insert image-address in the img-tag for having the images showing up to all users.
Or the forum receives some modification to unlock dropbox direct view.
You can open the image links in new browser windows.
https://www.dropbox.com/s/4ky6ok2ou0tf2 … or_Amp.jpg
https://www.dropbox.com/s/sfqzcq27qud6m … nal_FX.jpg
https://www.dropbox.com/s/qiqvg22c2slng … ffekte.jpg
The dropbox link is not the real image-address.
The image-address is this :
https://uc497f24de2631dbc1f0186374a1.pr … armed=true
Wow! Thank you very much!
5 (edited by ramses 2024-08-21 15:48:25)
edoctor24 wrote:
Dear all,
dont mean to hijack this thread, just asking myself if i could achieve the opposite = use DAW channel with inserts as (soft-)FX for external gear. and then record the signal from the external gear back in the daw. how would i have to route that?
thank you and kind regards!
Please open a new thread, as I see no relationship to my topic "routing for external FX".
Thanks for your understanding.
sure thing! did so. thanks!
