WC (Word Clock) is not an option here, the devices do not support it, so the clock synchronization between BBF#1 and BBF#2 has to be done via digital link, in this case ADAT.
BBF#1 = clock master. In the RME driver settings: set clock source to “internal”.
BBF#2 = clock slave. In the RME driver settings: set clock source to “ADAT” (sometimes also called “optical”).
You need two TOSLINK cables:
1. For sending the clock from the master to the slave: BBF#1--ADAT OUT------ADAT IN--BBF#2
2. to route the analog channels from BBF#2 to BBF#1: BBF#2--ADAT OUT------ADAT IN--BBF#1.
According to standards, cable lengths of up to 10 m are allowed, but usually 15 m will also work flawlessly. I have had good experiences with TOSLINK cables from Mutec. Do not use TOSLINK cables with too thick sheathing (e.g., Sommer Cable), then the cables are too stiff and do not lay properly.
Important: make sure that you use the same ASIO buffer size for both devices in the RME Driver Settings to avoid a time offset of the audio channels.
Both devices have their own TotalMix FX instance. TM FX routing only works within one instance.
Therefore, it is best to route the 4 analog channels (Mic1+2, Analog 3+4) from BBF#2 to BBF#1 via ADAT.
For this, you need the 2nd ADAT connection, as already mentioned.
You can easily configure the routing for this in the TM FX instance for the BBF#2, best in submix mode. For this, you click the HW outputs ADAT 1+2 in the lowest row and pull the faders of the HW input AN1+2 IN up to 0dB. Do the same for ADAT3+4 OUT and AN3+4 IN.
If you have audio on the analog channels, then you should see audio arriving at the HW input ADAT 1…4 in the TM FX instance of BBF#1.
Now you can
— record these 4 analog inputs of the BBF#2 via the HW inputs ADAT1…4 IN of the BBF#1 and
— also use those channels for submixes at the BBF#1 for monitoring purposes
This saves latency that you would have when routing everything through the DAW via USB, which would have been the other (worse) alternative, as you have then always the complete RTL (round trip latency) in the signal path.
And this RTL grows if larger ASIO buffer sizes are needed in certain situations.
PC
| | 2x USB cable
BBF#1---ADAT OUT-----------------TOSLINK cable#1------->-------------ADAT IN----BBF#2
(transport of clock signal+audio, if needed)
BBF#1---ADAT IN--------<----------TOSLINK cable#2---------------------ADAT OUT--BBF#2
(transport of the 4 analog channel)
BR Ramses
