Topic: What would cause delayed onset of constant crackles?
I just got a new laptop and am getting constant crackles on a project that ran fine on my previous laptop. However, the crackles don't start until several minutes after opening the project and they start off with one or two and slowly build until they're pretty constant. The delay scales with buffer size - larger buffers result in longer delays until the crackles start but once they start they progress until they sound about the same. So buffer size determines when the crackles start but not the severity of the crackles.
Also, the crackles occur without any indication of audio dropouts on the Cubase ASIO meter. The meter never shows an overload.
Can anyone think of how I might fix this problem? Or what could be causing it?
Thanks,
rgames
