After reinstalling Monterey, nothing has changed. Which basically means that removing ACE had no effect on coreaudio latency performance. Were things faster with ACE or was I imagining things? I'll look into that later but I asked Rogue Amoeba and they don't think ACE should have any effect either way. For now, ACE stays uninstalled. In case you're curious, here are a few represenative numbers. SR 44.1, Buffer 64 = 9.6 ms, Buffer 128 = 12.5 ms. SR 88.2, B 64 = 7.8 ms, B 128 9.2 ms. SR 192 B 64 = 6.9ms, B 128 =7.6ms. Overall, performance is pretty much in line with what you see in most coreaudio devices. From what I've seen, the gains from custom drivers seem to come mostly at higher sample rates (i.e. those crazy <3ms times). And yes, I know the ADI-2 Pro line aren't "interfaces." I'm not asking it be something it's not. And no, I'm not going to buy a Babyface.
