Topic: ASIO MADIface USB for Foobar 2.0-X64?
During the last weeks I have tested the new Foobar 2.0 with my ADI-2 Pro AE using the ASIO MADIface USB each in the 32-bit and 64-bit Foobar version.
The 32-bit version is working perfectly but it seems that there is no 64 bit version of the ASIO Madiface driver.
If this is the case is it planned to implement a 64 bit version?
Thank you for your feedback
Win10 Pro, ADI-2 Pro, Basis 1, Adam A3X; RL 906; Grace M902B, Glockenklang Bugatti, Strauss SE-NF-3
2 (edited by ramses 2022-10-11 18:26:49)
Re: ASIO MADIface USB for Foobar 2.0-X64?
I am not aware of that RME has or distinguishes between 32 and 64 bit drivers.
Could you kindly tell, which file you downloaded and installed?
From what I can see, the MADIface uses the same driver as, e.g., UFX+ and many other current interfaces.
https://rme-audio.de/downloads/driver_m … _09794.zip
According to the README, the last change for the MADIface USB in this driver was in v 0.9609, April 2017.
As this is no complex interface with plenty of port types, this looks fair enough to be called, up-to-date enough.
More details, please, error messages, … Maybe a screenshot of the configuration of the RME ASIO driver in foobar v2.
Did you already cross-check with the old / mature foobar v1.x? Maybe a bug in the new v2?
3 (edited by beat8000 2022-10-11 19:41:35)
I have downloaded and installed the driver version 9794.
This version is also visible in the following screenshots of the ASIO Madiface and foobar 2.0-x32:
foobar 1
https://www.dropbox.com/s/xdfx51ha7dp3a04/foobar-1.PNG?dl=1
foobar 2
https://www.dropbox.com/s/vk7ls6psjefenh1/Foobar-2.PNG?dl=1
foobar 3
https://www.dropbox.com/s/aqnzoxb2wvzx0lu/foobar-3.PNG?dl=1
Madi 1
https://www.dropbox.com/s/fw9mjll5w0i7re7/madi-1.PNG?dl=1
Madi 2
https://www.dropbox.com/s/hcqppqxmsxrkw10/madi-2.PNG?dl=1
Additionally a screenshot of foobar 2.0-x64 shows that no connection to the ASIO Madiface could have been established:
Foobar x-64
https://www.dropbox.com/s/zqmfrtocmxea0bs/foobar-x64.PNG?dl=1
I haven't crosschecked it with foobar 1.0 because a 64-bit version did not exist.
The driver's 64 bit ASIO dll is in use with nearly any other software out there...
I think it is not important whether you use foobar in 32 or 64 bit.
The MADIface driver can be used with Cubase 64 bit, so I think it is not the issue that the MADIface driver wouldnt support 64 bit applications.
6 (edited by beat8000 2022-10-11 23:55:39)
If I understand it correctly this would mean that there might be a Foobar connection error.
Is it possible to fix this error e.g. with a start of a service or a registry correction?
7 (edited by beat8000 2022-10-11 21:35:34)
Ok, I could fix this error mainly by restarting the PC after a beta 11 x64 installation:
https://www.dropbox.com/s/b5h3f8542b66a66/foobar-64.PNG?dl=1
For my favorite upsampling functionality I have already installed a new 64 bit Sox resampler
Now I should get rid of all Foobar preinstall directories and registry entries for all installed X-32 and x-64 beta versions. Obviously there are still some Beta 4 x64 elements taken either from the registry or from a preinstall file.
After that I will have to configure all the advanced settings manually
