Topic: Additional ideas to help me integrate my ADI PRO 2 FS into studio?
Hello there,
I have thought long and hard about my current setup and I think I know the only possible choices but I thought I'd ask people here for alternate ideas.
Currently, I am using a UFX (gen1), a Ferrofish A32 Pro and an ADI 2 Pro FS. The ADI 2 Pro FS is connected via the AES/EBU on the UFX. The A32 Pro is connected to the UFX via ADAT but I cannot utilise all 32 channels on the ferrofish at the moment because the UFX Gen 1 does not have enough ADAT ports.
What I am thinking of doing: Selling the UFX Gen 1 and buying an internal card like a HDSPe Madi, Madi FX or Ray Dat. I don't want a UFX+ because to be honest it is an overkill. I don't use the RME preamps, midi ports or any unique features. I simply use it as a low latency audio interface. I've owned my UFX for probably 10 years. In those days, I didn't have much and used more of the features on the UFX. Now they are not needed and never get used.
The Madi FX is beyond what I need. I don't need 2 Madi ports. I don't plan to expand the amount of I/O in the future. I literally just need a low latency internal card, preferably with 1 Madi port. The HDSPe Madi is a lower cost solution but it doesn't have an AES/EBU connector like the Madi FX, so how would I be able to connect the ADI 2 Pro FS? (All the adat ports on the Ferrofish A32 Pro would be used up for other things). I am also considering the RAYDAT which is very cost effective and has an AES/EBU connector plus enough adat ports to accommodate all the inputs and ouputs of Ferrofish A32. However, I'd have to run 8 Toslink cables around 2 - 3 meters and its just more cable and I was hoping a solution with less cables.
Any other ideas that are cost effective that will allow me to integrate my ADI 2 Pro FS? I'd buy the MADI FX in the heart beat but its quite expensive and it is an overkill. However, if it is my only option I will go for it.
Thanks in advance.
