1 (edited by jesill 2022-10-14 06:05:22)
Topic: Using Babyface pro fs and Raydat
I am using logic pro and Raydat with 2 Apogge Rosettas for analog summing.
For this setting I want to integrate Babyface pro fs as a ad/da converter in the Raydat system for picking up the analog stereo output of the summing mixer and  put it back to logic via Adat. The Babyface main outputs feed the monitor controller, the main Inputs are fed by the analog outputs.  No need for fx or Dsp in this setting. The system clocks at 48 khz.
Should I run the Babyface in PC or CC mode and should I use the Babyface as clock master?
Thanks in advance
Jens
P.S. The Babyface has an external original RME Power supply
J. Illmann, Mannheim
RayDat, Babyface pro fs, Apogee Rosetta 800, Little Vintage Maker
Re: Using Babyface pro fs and Raydat
For this simple I/O task you could go either way. Personally I would use PC as I want to see the routing and levels in TM FX.
Thanks a lot!
