Topic: headphone routing.
Hi Gang:
I'm sure that this has been covered before but, I am using loopback on one of the ADAT channels in order to send the audio to Zoom.  My question is, is there a way to rout the headphones to an ADAT channel?
The reason I need to do this is because I want to monitor the actual sound that is sent out to Zoom.
This is a little tricky since, as a Blind Babyface Pro Fs owner, I also need to monitor my computer screenreading program without sending the computer screenreading speech to Zoom.
Any help would be appreciated all over the place.
Re: headphone routing.
Loopback only works from an output to the same input. Phones 3/4 will directly loop to input 3/4. You can route the signal going to phones also to any ADAT output (use the output mirror function) and activate loopback then to have it on an ADAT input.
