1 (edited by jaychoupp 2022-10-29 21:42:39)
Topic: Adi2Pro as ADDA,no analog ad convertion happening...
I recently bought a 802 and want to connect adi2pro as adda,my setting is this:
1 Adi2pro Aes/ebu In/out connected to 802 Aes/ebu Out/in
2 Adi2pro set as ADDA mode,source setting is "auto"
3 802 as usb interface connecting to the computer,using totalmix to route signal
the situation is:
1 DA(802 aes out to Adi2pro aes in,then analog out ) is perfect,just route the signal to AES out in total mix,adi2pro can convert it to analog
2 AD (Adi2pro analog in to aes out,then to 802 aes in)isn‘t happening,although I can see analog in signal on Adi2pro's Analog Input(by small screen),but nothing shows in the total mix(I route all Inputs on totalmix to Main/AES.faders are up)
Firstly I thought maybe it was the aes cables so I switched them(ADtoDA and vice versa),still the same,then I connected an Adat cable,not working.
Seems the signal is not converted by adi2pro,get stuck between AD conversion and never goes to the 802/Totalmix successfully
Can anyone help me?thx a lot!
Re: Adi2Pro as ADDA,no analog ad convertion happening...
Look at the block diagram manual page 38.
The only option to switch off AD to AES out is “Dig. Out Source”.
Set:
SETUP / Options / Device Mode/DSD / Dig. Out Source / “Default”
Set:
Thx,so if I set source to be “Default”,adi2pro can automatically detect analog input and convert it to digital,then send to adi2‘s AES out,right?
Set:
It does.
