Topic: Total Mix window do not react to green button
Using MacBook Pro 16inch 2019 Intel Core i9 8 core just after update to macOS Ventura version 13.0, I update the TB and USB drivers as well as the firmware of my fireface UFX+ to the last version available.
I do the same with my Babyface Pro too.
I have a strange issue using both the interfaces: pressing the green button on the top left of the screen witch should normally make disapearing the "TotalMixFX-File-Function-Options-Window-Help" menu bar, and make the window "full"of totalmix, it stay like before (I use the 135% window size)
The problem is that using the fireface UFX+ i can not see the "record view" button. To see it I have to use 100% window size
Before the update, the green button work.
Should i set something?
Is it a bug?
Thank in advance for Your help
Paolo Giuseppe Bassi
