Topic: HDSP MADI FX - AES output not available in some apps
This normally not an issue as I only see the problem in certain cases - For instance:
In Kontakt SA (standalone) the AES output doesn't show up as a possible choice, only the MADI instances.
I've recently taken on the task of learning Protools and have a similar issue there, Unlike Kontakt SA, PT can "see" the AES out but no matter what I try, Protools will not output on the AES buss, but has no problem with any of the MADI outs.
Is there something unique with the AES / Phones outs?
Re: HDSP MADI FX - AES output not available in some apps
Yes, too many channels for some apps, and unequal number of inputs (194) and outputs (196). Both point to sloppy programming in the respective app...
