Topic: FF802 - electrical noise from some analog inputs with new computer
I'm setting up a new computer with the exact same electrical/audio connections to my FF 802 as my old machine and suddenly I'm hearing noise on a few of the channels. I've swapped machines a couple times to ensure the noise is associated with the new computer - it definitely is.
The noise goes away if I put a ground lifter on the new computer but it does *not* go away with everything plugged into a single outlet. Shouldn't that do basically the same thing, i.e. ensure everything is on a common ground?
Anybody have any ideas on how to fix this issue?
Thanks in advance,
rgames
