Topic: Correct gain setting for Fireface UFX II inputs for Eurorack signals?
I'm new to TotalMix FX. I will be recording Eurorack modular synthesizers, which have a high-intensity signal level. So I want to lower whatever gain is applied to the incoming signal.
For the rear panel inputs on the Fireface UFX II, such as AN 1, do I set the gain level toggle to "Lo Gain" in TM FX? This is equivalent to accepting a maximum signal level of +19dBu?
For the front panel MIC/LINE inputs, I was told by a friend who uses Eurorack to click the "Instr" button, that is, set it to 'Instrument' level. But would I not want it to be 'line level', that is, without the pre-amp that is applied to instrument level signals coming in? (That is, 'line level' comes in at a higher volume, which I would assume correspond to Eurorack signal levels). But as I understand it, you need to set the Fireface input to 'instrument' in order for it to use the TRS input, not the XLR input on the front panel inputs. Also, the manual says "The unbalanced TRS Line inputs [on the front panel]...handle levels from -21dBu up to +21 dBu, turning them into full level Line inputs." So it would seem one can use them for high-signal-level line inputs.
Thanks for any help!
