Topic: Auto gain setting option ? (Babyface Pro)
Hi
Is there an option to automatically adjust the gain of an input, meaning when the option is engaged, the gain will be lowered if it detects clipping ?
I'm using a Babyface Pro on a mac
Re: Auto gain setting option ? (Babyface Pro)
grandpaface wrote:
Hi
On many RME interfaces yes, but not on the Babyface.
Babyface Pro FS, MSI GS66, Studio One
3 (edited by ramses 2022-12-14 12:53:36)
The feature is called Autoset.
Available on (from memory):
     (UCX, UFX), UCX II, UFX II, UFX+
and the following preamps:
     Micstasy, XTC and 12Mic.
I use it often to find optimum level on UFX+ for Instr inputs (e.g. for e-guitar). But during use I turn it off to stay exactly on this level.
As my humbuckers are nearly at the same level I store the settings in a TM FX snapshot to have it ready for use.
You can leave it on for Mics, but if somebody touches the Mic hard, you might get a high peak input signal. Then Autoset automatically adjusts the input gain down. But then the rest of the recording might suffer from a too low input gain / level.
You need too check what makes more sense, to use it once to find proper gain with a good threshold (-6 dB if I remember right) and to keep it on or not.
