Topic: Fireface UFX: noise after turning on the effects processor
After turning on the effects "Reverb" or "Echo", there is noise at the output. In this case, both effects do not work. The screen recording can be viewed at: https://drive.google.com/file/d/1hM6_GK … share_link
The rest of the audio interface is stable: https://drive.google.com/file/d/1hHjLVV … share_link
Maybe you need to check the electrolytic capacitors at the output of the power supply?
Re: Fireface UFX: noise after turning on the effects processor
https://forum.rme-audio.de/viewtopic.php?id=29899
I understand. Thank you so much...
