Topic: Fireface UFX question - changing the default outputs
Out of the box, the Fireface UFX allows you to cycle between 3 main output sources when clicking in the rotary encoder. AN1/2, PH9/10 and PH11/12.
In TotalMixFX, if I reassign main (AN1/2) to something else like AES, this assignment is reflected on the LCD screen on the Fireface. However, if I reassign Headphone 1 or Headphone 2 to a different output, such as AN5/6, the change is not reflected and adjusting the rotary encoder while selecting Headphones 1 or Headphones 2 does not change the assigned output, only the default channels (AN9/10, AN11/12).
Is this intentional? Am I able to assign a new output for "Main" but not for "Phones 1" or "Phones 2"?
How can I make it so clicking the rotary encoder switches between AES, PH9/10 and AN5/6-- rather than AN1/2, PH9/10, PH 11/12?
