1 (edited by mruebsamen 2023-01-04 18:57:54)
Topic: AVB controller doesn't start anymore
dear AVB users,
after a reinstall of MacOS Monterey (10.12) the RMEAVB Controller.app (version 0.9566) doesn't start anymore.
I installed the latest official USB driver 3.28 as well as the latest beta driver 4.06. I also installed the latest firmware update for the DIGIface AVB (Firmware v252). When I start the app from command line, I get the following message:
"2023-01-04 17:15:55.954 RME AVB Controller[1039:13511] Warning: Column selection is not supported in view-based table and outline views (<NSTableView: 0x7f9ba5832400>).
Found Digiface AVB (vendor = 10809, product = 16370)
Digiface AVB = feth10002
Unable to open the adapter. feth10002 is not supported by pcap.
kein Digiface gefunden
!!!Network open!!!
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Prozess beendet]
I understood the the Digiface hast the name set.10000... Is this maybe the issue?
Re: AVB controller doesn't start anymore
Do you have and intel or arm mac?
Did you install netifc (the network interface)?
Please check: type ifconfig at the command line. What network interfaces do you see? Is feth10000 listed? Is it up?
3 (edited by mruebsamen 2023-01-04 23:01:14)
It's an Intel based Mac Pro (OS 12.6.2, 10 Core, 64 GB)
and yes feth10000 is listed
"feth10000: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 66:65:74:d9:c8:d7
    inet6 fe80::1cbe:6c71:3bd1:405a%feth10000 prefixlen 64 secured scopeid 0xa
    inet 169.254.107.178 netmask 0xffff0000 broadcast 169.254.255.255
    peer: feth10001
    nd6 options=201<PERFORMNUD,DAD>
    media: autoselect
    status: active
4 (edited by uwekirst 2023-01-06 13:31:42)
I have been running OS 12.3 smoothly. I have also an Intel Mac Pro, I'm installing 12.6 now.
Can you please do the following: Install Hive, select Digiface (feth10000) as interface and see if you can discover any AVB device which is connected to the network port of the digiface.
Halo Uwe, danke für die Antwort. Lag heut mit Grippe im Bett.
Ich werde es gleich morgen ausprobieren.
It looks like it works now. I just reinstalled everything again (third time with the public USB driver 4.06)
Thank you...
