Hi David,
welcome to the RME user forum.
davidlaijiajun wrote:[...]thanks to remote assistance from a friend, I was able to get loopback working on my main outs (AN 1/2). However, the recorded signal is dependent on the volume fader. If I get the monitor volume to a comfortable listening level, the recorded audio has a very low volume. Conversely, to get a healthy volume on my recordings, I'll need to crank the volume to maximum to let the meters show a healthy level. I can't adjust the volume on my monitors because they have separate volume controls, and the knobs at the back only go by 0.1 DB per click, and I can't do this well because of my blindness.
The reason is, that the loopback implementation of the Babyface Pro FS is "post-fader". With some interfaces (like UCX II) loopback is implemented "pre-fader" which would be more useful in your case.
davidlaijiajun wrote:1. Is it possible to let the loopback audio not be effected by how loud or soft I adjust the volume faider for my hardware outputs?
2. If this isn't possible, can I use the remaining output channels as virtual loopback ports? Let me explain what I'm imagining.
Say if I routed the audio using TotalMix FX to also output on outputs 3/4 (if such hardware outputs exist). I set the volume of the output faider on this new output to maximum, and I loopback this audio into Analogue inputs 3/4 (if such inputs exist). Then what can happen is, no matter how loud or soft I adjust the volume for outputs 1/2, it won't effect the volume for outputs 3/4 and I can get good recordings using the inputs 3/4. The only thing is, I won't be actually using outputs 3/4, or analogue inputs 1/2 for that matter, but that's OK. 2 pairs of WDM devices shouldn't be too much of a problem.
Is my imagination crazy? Or is there an easier way to do all this loopback trick?
Your idea is correct, you could send audio to any other unused HW output (analog or digital, doesn't matter) for loopback purposes. This is only possible if all applications allowed to configure any I/O port as audio input, sadly this is not the case.
Windows: types of audio applications
To give you an overview, the following type of application you experience on a Windows computer:
a) Applications with ASIO support are the best, here you can select any of the HW inputs for recording.
b) Applications without ASIO support need a WDM driver that you can create in the RME driver settings (for any I/O port).
The issue here is that only some applications have the possibility to select *any* WDM driver of your system.
Some applications can only read from the Windows Standard Device for Recording (that you need to define system-wide in the Windows Sound settings) or maybe only from the 1st detected input.
Two solutions
You could switch to a recording interface like the UCX II, which has a pre-fader loopback implementation, but I think the following two options are more relevant to solve the issue for you:
Option 1)Passive volume controller: because it doesn't cost much, is easy to implement and solves the issue entirely.
Option 2) ADI-2 DAC/Pro FS: costs more, solves the issue entirely, but gives you a lot of very useful features on top, and you have the best reference converter that you can get for the money. With useful features that are unique to these devices.
Here the two possibilities in detail:
1. Passive volume controller
The cheapest solution is to use a passive volume controller between Babyface Pro AN 1/2 OUT and active monitor to turn down the volume. Some people on forum often mention this product here:
https://www.thomann.de/de/tc_electronic_level_pilot.htm
Note, there are other solutions with additional functions like mute, mono mix, connecting a 2nd or 3rd pair of monitors, subwoofer and "what not", see this list of Studio/Monitor controllers from Thomann:
https://www.thomann.de/de/studio_monitorcontroller.html
2. Integration of ADI-2 DAC FS or ADI-2 Pro FS into your setup
This is the most expensive, but IMHO the best solution that you can get. The ADI-2 DAC/Pro FS series of products are the best and most flexible headphone amps and high-quality converter on the market, with advanced / unique features like:
- 4 different reference levels for analog outputs (Pro: also inputs)
- auto-reference level to dynamically select the ideal reference level to maximize SNR / DR (dynamic range)
- dynamic loudness to increase Bass/Treble dynamically over a range of 20dB (Bass and Treble gain user configurable up to 10 dB).
Regarding dynamic loudness. Very useful for office work so that the sound doesn't become too thin on lower volumes. During office work I need sometimes background music, and then it is wonderful, that the sound at lower volumes is still kind of "rich and full".
Maybe your friend can support you to get the relevant information for you out of this blog article,
which is about the different models and features of ADI-2 DAC FS and ADI-2 Pro FS R BE:
https://www.tonstudio-forum.de/blog/Ent … ses-EN-DE/
If this were an interesting option for you, then I can support you, selecting the proper model for you.
Option 2 - Connection to recording interface and benefits
You could connect the ADI-2 DAC or ADI-2 Pro via ADAT/SPDIF to your Babyface Pro to have lossless transfer of digital audio through ADAT or SPDIF (ADI-2 DAC/Pro understand both protocols).
Now you get multiple benefits at the same time:
1. Speakers and phones are connected to the ADI-2 DAC/Pro, so the volume for monitoring is now being controlled at the ADI-2 DAC or Pro.
2. As your active monitors are not connected anymore to the HW output AN 1/2 of the Babyface Pro, you can keep the fader of HW output AN 1/2 at 0dB, so that you have no issues anymore with loopback recording (and post-fader implemenation).
3. You standardize your setup in terms of loopback recording, as all of your applications can record loopback audio now from HW input AN 1/2. No need to change anything anymore, which, I think, is very useful for you to make things simpler.
4. You do not need to worry about level mismatches anymore. The ADI-2 DAC/Pro remember the volume settings for all analog outputs (monitors/phones), comparable to the passive monitor controller. So, an accidental double-click to an output fader in TM FX doesn't lead to a very high volume, which could be bad for your monitors and ears if the level mismatch were very high (very sensitive/loud monitors).
ADI-2 DAC/Pro - Further benefits of key mapping
I think the solution with ADI-2 DAC/Pro would also have other little benefits to you, as the four keys in the front are user-assignable. In the following blog article, I described the integration of the reference converter into an RME setup and make proposals for useful key mappings for the front key.
https://www.tonstudio-forum.de/blog/Ent … our-Setup/
By this, I am able to
- switch between monitors / phones
- toggle activation / deactivation of PEQ, active loudness, Bass/Treble if you want to ensure to have the original signal
- mute all outputs, I am using the last key for this because this is quickest to find/select with the hand even if I do not look into that direction. Your friend can have a look at the article to see, how you can implement this easily.
I am also using two ADI-2 Pro FS R BE, one in the recording corner, one in the HiFi corner. I'm so excited about the quality and unique features of the devices, that I couldn't do without them.
If there are any remaining questions about the one or other solution, I am happy to further support you.
Do not hesitate to ask further questions if needed.
