Topic: High Impedance Headphones & UCX II
Hello everyone,
I want to use headphones with high impedance as 470 Ohm.
For that matter the headphones is Audio-technica R70x
Will the card will work fine with this kind of headphones ?
Re: High Impedance Headphones & UCX II
Sure. Zero issue.
Finally I bought BeyerDynimics DT990 Edition - 250 Ohm
It works well...
What would be the lowest impedance of a head phone which can still be driven reasonably?
From the manual: This low impedance output of highest quality is able to drive headphones at higher levels undistorted, no matter if low or high impedance headphones are used.
Output impedance is 1 ohm.
Babyface Pro FS, MSI GS66, Studio One
