Topic: Ms proc
Hi my ufx sounding worse.
when i turn on Ms proc The L R sound doesnt go to the right Channel
Re: Ms proc
If you send a MS (Middle/Side) encoded signal to an MS Processor, and monitor the output as Ch. 1 going to the left speaker and Ch.2 to the right, output will be Left/Right, or normal stereo.
If you send a Stereo (Left/Right) signal to the same MS Processor, the output will be very much like what you describe, because in most cases, the Center signal contains more energy than the Side. If you send a two channel Mono signal to an MS Processor, the output will be all on the left, with nothing from the right.
What kind of signal are you sending to the processor? What are you seeking to achieve?
Frank Lockwood
https://LockwoodARS.com
Fireface 800, Firmware 2.77
Drivers: Win10, 3.125; Mac, 3.36
