Topic: DC 5 rc4 crashing with Fireface 800
Greetings,
After sitting idle for a few minutes (probably 2-3) Digicheck 5rc4 causes an error message asking to close.  I can send the error log if needed.  It appears to be a regular polling interval for the Fireface driver or Digicheck as the error/crash occurs after 2-3 minutes everytime I open it.
This is with Fireface drivers 2.56, hardware revision 2.59.
I love the new surround metering in DC 5!
Dedric
Re: DC 5 rc4 crashing with Fireface 800
kdm wrote:
Greetings,
Dedric,
I suggest you update your drivers...
There is also now an RC4 of Digishcek.
David
Classical ambisonic surround recording: UFX, FF400, Alesis HD24, Edirol R-44/88, Samplitude ProX 3.
Thanks David - updating drivers here and on the other machines is on the list once I have some breathing room between projects.  I know I'm way behind on drivers at this point.
I actually saw this with both RC2 and now RC4.  Since you list a FF800 in your config, I'm guessing it's a issue with the older FF drivers.  I'll post results when I update - hopefully in a few days.
