1 (edited by kuncarp 2023-01-30 12:18:32)
Topic: Digiface prevents Macbook from shutting down
I have an issue with Macbook Pro Mid 2014, i7, 16GB - macOS 10.15.7 When I work with connected RME Digiface AVB and want to switch the computer off, it keeps restarting. I have tried everything found online (resetting NVRAM etc.) and nothing helps.
When I disconnect Digiface while running, Macbook shuts down and reports a mistake. It is happening with both USB ports.
Has this happened to anyone? Is it a macbook issue?
Pavel Kunčar
Report:
panic(cpu 6 caller 0xffffff8019991e7e): "A kext releasing a(n) IOUSBHostInterface has corrupted the registry."@/AppleInternal/BuildRoot/Library/Caches/com.apple.xbs/Sources/xnu/xnu-6153.141.2.2/libkern/c++/OSObject.cpp:224
Backtrace (CPU 6), Frame : Return Address
0xffffff81f8943b70 : 0xffffff801931868d
0xffffff81f8943bc0 : 0xffffff8019452ab5
0xffffff81f8943c00 : 0xffffff801944463e
0xffffff81f8943c50 : 0xffffff80192bea40
0xffffff81f8943c70 : 0xffffff8019317d57
0xffffff81f8943d70 : 0xffffff8019318147
0xffffff81f8943dc0 : 0xffffff8019abf2bc
0xffffff81f8943e30 : 0xffffff8019991e7e
0xffffff81f8943e40 : 0xffffff7f9abf3873
0xffffff81f8943e70 : 0xffffff8019992ad1
0xffffff81f8943ea0 : 0xffffff80199928a6
0xffffff81f8943ec0 : 0xffffff80199b3bac
0xffffff81f8943ee0 : 0xffffff8019a009a4
0xffffff81f8943f60 : 0xffffff8019a0ac87
0xffffff81f8943fa0 : 0xffffff80192be13e
      Kernel Extensions in backtrace:
         com.apple.iokit.IOUSBFamily(900.4.2)[15879BD6-8025-376B-9085-F56C7C002FB1]@0xffffff7f9ab9b000->0xffffff7f9ac33fff
            dependency: com.apple.iokit.IOPCIFamily(2.9)[2F37AE58-E6B9-3B18-9092-3B80D34C334B]@0xffffff7f99d31000
            dependency: com.apple.iokit.IOUSBHostFamily(1.2)[80AD6206-0EDB-39B5-A7B9-8FEAFD6407F3]@0xffffff7f9a9fe000
            dependency: com.apple.driver.usb.AppleUSBCommon(1.0)[B5515CE4-E548-3AEE-9980-1967FB191C23]@0xffffff7f9a9ec000
BSD process name corresponding to current thread: kernel_task
Mac OS version:
19H15
Kernel version:
Darwin Kernel Version 19.6.0: Thu Oct 29 22:56:45 PDT 2020; root:xnu-6153.141.2.2~1/RELEASE_X86_64
Kernel UUID: 9B5A7191-5B84-3990-8710-D9BD9273A8E5
Kernel slide:     0x0000000019000000
Kernel text base: 0xffffff8019200000
__HIB  text base: 0xffffff8019100000
System model name: MacBookPro11,3 (Mac-2BD1B31983FE1663)
System shutdown begun: YES
Panic diags file available: NO (0xe00002cd)
System uptime in nanoseconds: 2879429403164
last loaded kext at 2016597078880: >!AHIDKeyboard    209 (addr 0xffffff7f9d24a000, size 36864)
last unloaded kext at 2009190345214: |IOUSBMass!SClass    4.0.4 (addr 0xffffff7f9adec000, size 69632)
loaded kexts:
de.rme-audio.driver.RMEFirefaceUSB    3
de.rme.RMEUSBNetworkDriver    1.0.3
@filesystems.smbfs    3.4.4
>!A!BMultitouch    97
@fileutil    20.036.15
>AGPM    111.4.4
>!APlatformEnabler    2.7.0d0
>X86PlatformShim    1.0.0
>AudioAUUC    1.70
@filesystems.autofs    3.0
>!AHDA    283.15
>!AUpstreamUserClient    3.6.8
@GeForce    14.0.0
>AGDCBacklightControl    5.2.6
>eficheck    1
>!AGraphicsDevicePolicy    5.2.6
>!ALPC    3.1
@AGDCPluginDisplayMetrics    5.2.6
>!A!IHD5000Graphics    14.0.7
>!AHV    1
|IOUserEthernet    1.0.1
|IO!BSerialManager    7.0.6f7
>pmtelemetry    1
@Dont_Steal_Mac_OS_X    7.0.0
>!ASMCLMU    212
>!AMCCSControl    1.14
>!A!IFramebufferAzul    14.0.7
>!ACameraInterface    7.6.0
>!A!ISlowAdaptiveClocking    4.0.0
>!AMuxControl    5.2.6
>!AThunderboltIP    3.1.4
>!UTCKeyboard    255
>!UTCButtons    255
>!UCardReader    489.120.1
>!AVirtIO    1.0
@filesystems.hfs.kext    522.100.5
@!AFSCompression.!AFSCompressionTypeDataless    1.0.0d1
@BootCache    40
@!AFSCompression.!AFSCompressionTypeZlib    1.0.0
@filesystems.apfs    1412.141.1
>!AAHCIPort    341.140.1
@private.KextAudit    1.0
>AirPort.BrcmNIC    1400.1.1
>!ASmartBatteryManager    161.0.0
>!AHPET    1.8
>!AACPIButtons    6.1
>!ARTC    2.0
>!ASMBIOS    2.1
>!AACPIEC    6.1
>!AAPIC    1.7
$!AImage4    1
@nke.applicationfirewall    303
$TMSafetyNet    8
@!ASystemPolicy    2.0.0
|EndpointSecurity    1
>!AHIDKeyboard    209
>IO!BHIDDriver    7.0.6f7
>!AMultitouchDriver    3440.1
>!AInputDeviceSupport    3440.8
@kext.triggers    1.0
>DspFuncLib    283.15
@kext.OSvKernDSPLib    529
@nvidia.driver.NVDAGK100Hal    14.0.0
@nvidia.driver.NVDAResman    14.0.0
>X86PlatformPlugin    1.0.0
>!ABacklightExpert    1.1.0
>IOPlatformPlugin!F    6.0.0d8
|IOAVB!F    850.1
@!AGPUWrangler    5.2.6
|IONDRVSupport    576.1
>!AHDA!C    283.15
|IOHDA!F    283.15
@plugin.IOgPTPPlugin    840.3
|IOEthernetAVB!C    1.1.0
>!ASMBus!C    1.0.18d1
|IOAccelerator!F2    438.7.3
|IOSlowAdaptiveClocking!F    1.0.0
@!AGraphicsDeviceControl    5.2.6
|IOGraphics!F    576.1
>!AGraphicsControl    5.2.6
|Broadcom!BHost!CUSBTransport    7.0.6f7
|IO!BHost!CUSBTransport    7.0.6f7
|IO!BHost!CTransport    7.0.6f7
|IO!B!F    7.0.6f7
|IO!BPacketLogger    7.0.6f7
>!UMultitouch    264
>usb.IOUSBHostHIDDevice    1.2
>usb.networking    5.0.0
>usb.!UHostCompositeDevice    1.2
>usb.!UHub    1.2
|IOAudio!F    300.2
@vecLib.kext    1.2.0
|IOSerial!F    11
@filesystems.hfs.encodings.kext    1
|IOSurface    269.11
|IOAHCIBlock!S    316.100.5
|IOAHCI!F    290.0.1
>!AThunderboltDPInAdapter    6.2.6
>!AThunderboltDPAdapter!F    6.2.6
>!AThunderboltPCIDownAdapter    2.5.4
>!AThunderboltNHI    5.8.6
|IOThunderbolt!F    7.6.1
|IO80211!F    1200.12.2b1
>mDNSOffloadUserClient    1.0.1b8
>corecapture    1.0.4
|IOSkywalk!F    1
>usb.!UXHCIPCI    1.2
>usb.!UXHCI    1.2
|IOUSB!F    900.4.2
>!AEFINVRAM    2.1
>!AEFIRuntime    2.1
|IOSMBus!F    1.1
|IOHID!F    2.0.0
$quarantine    4
$sandbox    300.0
@kext.!AMatch    1.0.0d1
>DiskImages    493.0.0
>!AFDEKeyStore    28.30
>!AEffaceable!S    1.0
>!ASSE    1.0
>!AKeyStore    2
>!UTDM    489.120.1
|IOSCSIBlockCommandsDevice    422.120.3
>!ACredentialManager    1.0
>KernelRelayHost    1
>!ASEPManager    1.0.1
>IOSlaveProcessor    1
|IOUSBMass!SDriver    157.140.1
|IOSCSIArchitectureModel!F    422.120.3
|IO!S!F    2.1
|IOUSBHost!F    1.2
>!UHostMergeProperties    1.2
>usb.!UCommon    1.0
>!ABusPower!C    1.0
|CoreAnalytics!F    1
>!AMobileFileIntegrity    1.0.5
@kext.CoreTrust    1
|IOTimeSync!F    840.3
|IONetworking!F    3.4
|IOReport!F    47
>!AACPIPlatform    6.1
>!ASMC    3.1.9
>watchdog    1
|IOPCI!F    2.9
|IOACPI!F    1.4
@kec.pthread    1
@kec.Libm    1
@kec.corecrypto    1.0
Re: Digiface prevents Macbook from shutting down
Hi everyone,
this problem that happened also with DF Dante seems solved with new netifc driver.
Pavel
The OS is too old and the driver accesses addresses that do not exist in the API. The result is a crash...
Don't expect support for such an old OS. Try using an older version of the driver.
Hello, Digiface AVB had an issue (above) with one of the old drivers. the issue disappeared with version 3.222a and appeared again with 3.222b2. Digiface Dante had a different issue - dropouts and errors in USB connection (mainly with Win laptop - Thinkpad x270). The same happened - the issue was gone with driver 3.222a and appeared again with 3.222b2.
