1 (edited by lgibbs2 2023-02-01 22:28:15)
Topic: ADI-2 PRO FS R BE @ 96khz
Have an ADI-2 PRO FS R BE connected to a Antelope Zentour via adat and everything seems to be fine at 44.1 & 48khz in AD/DA mode. Been wanting to experiment with recording at 96khz but can't get them to sync. When I switch to 96khz the ADI-2 remains at 48khz. Are there additional settings?
Thanks!
Re: ADI-2 PRO FS R BE @ 96khz
The Antelope does not signal 96 kHz, so you have to manually set that sample rate at the ADI. This is possible in slave mode with ADAT.
Thanks got it sorted.
