Topic: Swap left/right channel
My headphones (Beyerdynamic DT1770) have cable conection on the left side. But I would prefere to have it on the right side. I could swap the headphone, but then I must swap the L/R signal/channel. Can I do it in ADI? Maybe I have overseen it.
If not, then I have to customize the connection cable.
2 (edited by KaiS 2023-02-07 00:06:59)
Re: Swap left/right channel
xajas wrote:
I must swap the L/R signal/channel. Can I do it in ADI? Maybe I have overseen it...
It‘s not obvious, but setting the “Width“ parameter to –1.0 does exactly that.
If this works, it is a great idea :-)
I will check it.
Thanks!
Just had a look, it‘s in the DAC manual page 21:
Width
Defines the stereo width. 1.00 equals full stereo, 0.00 mono, -1.00 swapped channels.
"Lesen bildet" :-)
The DT1770/DT1990 PRO has angled drivers. To use it turned around would not be recommended I would assume.
7 (edited by xajas 2023-02-08 14:01:41)
Thank you. Exactly
This is what I experienced yesterday. I tried it out, and swaping the singnal via RME works prfect, but the sound was different. My suspition was the internal (angled) construction of the drivers
