1 (edited by Viennacalling 2023-02-08 10:45:51)
Topic: Frage zu MacOS Digicheck NG und Adi-2 Pro
Nachdem mich am Spectralanalyzer peak hold beim Musikhören interessiert,  dachte ich, einfach am Mac Digicheck NG installieren und danach Qobuz vom Mac per USB zum Adi-2 Pro schicken.
Nun zeigt aber der Spektral-Analyzer gar nichts an.
In der Statusleiste oben steht aber: DigiCheck NG - prozessing active: Adi-2 Pro - 96.0k
Am RME kommen die Daten auch an.
Was muss man da aktivieren, dass der Spektral-Analyzer am Mac Daten anzeigt? - Danke
Vermutlich ein klassischer Anfängerfehler.
https://ibb.co/6PVkFgt
Adi-2 Pro, Adi-2 Dac Fs
2 (edited by waedi 2023-02-08 12:31:18)
Re: Frage zu MacOS Digicheck NG und Adi-2 Pro
ADI-2 Pro has an internal Loopback function !
Page 41 user manual.
Activate it and it will work.
In Digicheck : Right-click onto the analyzer tool and select input channel 1/2.
M1-Ventura, Madiface Pro, Digiface USB, Babyface silver
Sorry, i read page 41 but did not get any additional hint therefore
https://ibb.co/0GWrwqY
There are different ADI-2 Pros, I was watching into ADI-2 Pro FS BE, my bad.
Please search the pdf for Loopback, Command + F
If your device has no Loopback function then you need a special Loopback software like blackhole.
Digicheck monitors input channels only, and the software player send his audio to output channels only.
A Loopback software has to bring the signal to an input channel.
5 (edited by Viennacalling 2023-02-09 15:55:25)
Ok loopback is not a function of Adi-2 Pro
Thank you !!!
https://www.forum.rme-audio.de/viewtopic.php?id=24367
I tested digicheck because of this information - it would be an option to use digicheck to get peak-hold
https://forum.rme-audio.de/viewtopic.php?id=28548
