1 (edited by sophosutm01 2023-02-08 15:35:56)
Topic: Stock(original) firmware for RME ADI-2 DAC FS?
Hi
After updating my firmware to the latest this week I have got a issues with the sound.
It drops out in period Firmware V.51 78 0.9808
I did not have any issues before nothing has changed in my setup.
I have done all the troubleshoot needed.
I am only asking for a download link for ESS version, and please the one that came with the unit.
Firmware and driver please
Is this possible?
Re: Stock(original) firmware for RME ADI-2 DAC FS?
I guess Im have to throw this dac out.
Thanks for the help
3 (edited by KaiS 2023-02-09 09:08:31)
Maybe you just have to uninstall AND DELETE the driver if you had ADI-2 running without it before, and don‘t use ASIO software.
Look in the manual page 42 to see how to do it:
“To use Windows own Class Compliant drivers the RME driver has to be removed completely (for example after a firmware update). In Device Manager select the ADI-2 DAC under Sound, Video and Game Controllers, right click and choose Uninstall. In the next dialog make sure to check 'Delete the driver software for this device'. Otherwise the driver will stay within the Windows installation and gets reinstalled automatically after the next reboot.”
If this doesn’t help:
I have a firmware DAC V.48 here, if you pm me your email adress I could send it.
I loosely remember there was a firmware / driver archive somewhere, maybe @mc could chime in.
4 (edited by rawac 2023-02-09 11:39:20)
I have in my archive:
  1. fut_madiface_win(FPGA177_DSP87).zip
    ADI-2 Pro / AE FPGA 177, DSP 87 + ADI-2 DAC FPGA 20, DSP 21
  2. fut_madiface_win(FPGA193_DSP94).zip
    ADI-2 Pro FPGA 193, DSP 94 + ADI-2 DAC FPGA 26, DSP 30
  3. fut_madiface_win(FPGA213_DSP97).zip
    ADI-2 Pro FPGA 213, DSP 97 + ADI-2 DAC FPGA 27, DSP 33
  4. fut_madiface_win(FPGA213_DSP98).zip
    ADI-2 Pro FPGA 213, DSP 98 + ADI-2 DAC FPGA 27, DSP 34
  5. fut_madiface_win(FPGA238_DSP98).zip
    ADI-2 Pro FPGA 238, DSP 98 + ADI-2 DAC FPGA 34, DSP 34
  6. fut_madiface_win(FPGA249_DSP98).zip
    ADI-2 Pro FPGA 249, DSP 98 + ADI-2 DAC FPGA 35, DSP 34
  7. fut_madiface_win(FPGA250_DSP101).zip
    ADI-2 Pro FPGA 250, DSP 101 + ADI-2 DAC FPGA 35, DSP 35
  8. fut_madiface_win(FPGA250_DSP102).zip
    ADI-2 Pro FPGA 250, DSP 102 + ADI-2 DAC FPGA 35, DSP 35
  9. fut_madiface_win(FPGA254_DSP102).zip
    ADI-2 Pro FPGA 254, DSP 102 + ADI-2 DAC FPGA 35, DSP 35
  10. fut_madiface_win(FPGA259_DSP111).zip
    ADI-2 Pro FPGA 259, DSP 111 + ADI-2 DAC: FPGA 66, DSP 46
  11. fut_madiface_win(FPGA262_DSP112).zip
    ADI-2 Pro FPGA 262, DSP 112 + ADI-2 DAC: FPGA 78, DSP 48
  12. fut_madiface_win(FPGA262_DSP113).zip
    ADI-2 Pro FPGA 262, DSP 113 + ADI-2 DAC: FPGA 78, DSP 49
  13. fut_madiface_win(FPGA265_DSP116).zip
    ADI-2 Pro FPGA 265, DSP 116 + ADI-2 DAC: FPGA 78, DSP 51 + ADI-2/4 Pro SE FPGA 67, DSP 26
Which one do you want?
If Matthias Carstens allows it I could offer a Download.
Ralf
(ADI-2 Pro FS with ThinkPad Yoga L13, Dynaudio Focus 600 XD or Focal Clear — and a lot of Jazz)
5 (edited by sophosutm01 2023-02-09 12:44:50)
I am soo happy for help :-)
@KaiS: About troubleshooting I work in IT, I can write you a book on the troubleshooting side of this DAC :-)
-I have been through everything from layer 1(usb cables/port, network)...and there drivers including chipset.
-Completely manual removal of RME drivers, and clean installation of it, even a new flash again.
-Every service been through
-every driver of every other ASIO and sound card, even DAW related. Virtual stuff etc
-completely thourough registry tweaks
-BIOS power savings etc...
These are the few.
6 (edited by sophosutm01 2023-02-09 12:11:26)
If I remember correctly my DAC/ESS came with .47V firmware.
I am on 22H2 Windows 10 buil
-I am starting to suspect Windows now
7 (edited by KaiS 2023-02-09 13:33:37)
Might be, since Microsoft introduced the forced updates, Windows became a moving target.
Try:
• A different USB port, preferably opposed position like front<>rear.
• Swap USB cable for a short one, nothing fancy needed.
• Driverless like mentioned above, if this is an option for your purpose.
Try:
Done it  all
Only thing I have not tested is another pc, because I dont have one
Please help.
Can I get firmware .47V?
I have tested on 5 different computers now same problem with audiodropouts.
11 (edited by sophosutm01 2023-02-10 13:03:47)
Anybody?
1. I have tried different computer/builds
2. I tried the firmware 66/41
3. Its the only DAC that behaves like this. I have 3 other dacs working normal!!!
Please Help!!!!
You should.
How would you find out the issue is in the DAC ?
Did you not read my last post?
14 (edited by KaiS 2023-02-10 13:19:38)
Have you tried a full factory reset:
While powering up, hold Encoder 1, Encoder 2 and the VOL Button (NOT the Volume dial) until you see “ Reset done”.
This erases all user Presets and Setups, so if you have such...
The reset that preserves the user Presets and Setups is:
While powering up, hold Encoder 1 and the VOL Button (NOT the Volume dial) until you see “ Reset done”.
Yes I have done this on both firmware 78/51 and 66/41.
This is really strange.
The Problem seems to be issue between cpu and gpu!!!
After disabling my RTX gpu and using the APU it works!!
Everybody has issues with Ryzen 5000 series generally.
Every google search pointed me in issues with 5000 series
Sometimes funny tricks like switching on mouse trails help.
Not that exactly this is the solution in this case.
I have read about this a few times before, and I am curious to know, how it is related.
It does not solve my issue
