Topic: ADI-2 Pro FS R BE - PCM direct vs. DSD to PCM
I plan to use the ADI-2 Pro FS R to capture a final master from a hardware chain.
My distributor expects files in 192k/24-bit. So which is the best approach:
1) Record the audio at 192k/24-bit
2) Record the audio at DSD256, then use Saracon to convert offline to 192k/24-bit
(I would not mind having DSD for my own archive, but not at the expense of lower quality 192k file)
Thank you.
Re: ADI-2 Pro FS R BE - PCM direct vs. DSD to PCM
Use 1).
2) brings zero advantage.
