1 (edited by ghostmize 2023-02-17 22:07:30)
Topic: Babyface Pro's Volume Super low on ASIO - out of the blue
Hey all,
After long time of using the Babyface Pro without any issues,
all of a sudden I have a volume issue:
Basically it only happens when using ASIO (any DAW, I tried also in Traktor for example so I know it's not a plugin thing)
I used to set up the volume to about -24db and it was already loud enough.
Now, I have to bring it to 0db it order to be loud enough.
I tried both via monitors/headphones.
In Ableton, it seems like the volume issue is on the headphone channel.
In Traktor, it's both main output/headphones that suffer from it.
When using the non-asio drivers - RME(speakers) - which is what I always used for programs like Chrome/Windows apps in general - then it's fine - no change.
What could be messing up the volume on the ASIO only?
DIM is not on anywhere.
I also tried a total reset for TotalMix - no luck.
It's so strange...
Any ideas?
Thanks a lot
Elad
