Topic: Fireface 400 Clicking issue
Greetings,
I'm using a FF400 on a 2011 iMac running High Sierra OS 10.13.6. The FF has been a bit strange lately and over the last few days has produced intermittent clicks through the speakers even with the inputs muted and nothing plugged into them. The Front panel channel signal level LEDs are lit, presumably with some internal noise issue. I tried reflashing the firmware (1.71), but I receive the following message each time: "Failed with error D0000000". I've rebooted and even reinstalled the drivers; still can't flash the firmware.
The FF400 is now bricked. The drivers error out when they try to load on reboot. Any way I can reset this? Thanks so much in advance.
Kindest regards
